disable mpls
disable mpls
Description
Disables MPLS on the switch.
Syntax Description
Default
Disabled.
Usage Guidelines
When MPLS is disabled, no label traffic is received or transmitted, and all MPLS-related protocol peer sessions are terminated.
The following command globally disables MPLS on the switch:
disable mpls
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
